Every time I try and start a print it will auto pause/ park, when I press the button for it to continue it just parks again.
Is there any way to solve this? It’s on version 2.1.3.0.48
It sounds like you have the runout sensor enabled and are either not running the sensor, or it has some issue internally.
You can disable the runout sensor on the configuration menu on the printers LCD.
This should stop that from happening.
