Hi everyone, can anyone confirm if Semitic NTC 100k thermistor works with Taz 5 without any modification to the firmware? Here is a link to the thermistor I am planning to install: https://www.bhphotovideo.com/c/product/1618090-REG/lulzbot_kt_cp0110_100k_semitec_ntc_thermistor.html/qa
Hello,
If you are using the stock tool head on your TAZ 5, the NTC is not compatible as the thermistor used in the TAZ 5 is going to be the GT-2 glass bead style that we have on our website linked below.
Thank you for your reply. I am not using the stock tool head. I am using the E3D heating block and would like to use the ntc 100k thermistor. Do you know how I would be abke to use it?
