I wanted to write some custom gcode that controlled the individual extruder fans independently. I cant seem to get this to work. Each fan seems to be wired to its own fan control on the mainboard and the Marlin page shows how to control individual fans with the M106 command:
http://marlinfw.org/docs/gcode/M106.html
So I tried:
M106 P1 S255
M106 P2 S255
M106 P3 S255
Nothing works. Sending just M106 turns both fans on to max as expected, but I can’t control individually using P. Am I not indexing properly? Or is this something that is not enabled or something? If so, Why??
I’m presuming that your printer is a TAZ, with the two extruder fans on each side and the hot-end cooling fan on the front of the print head, right?
The cooling fan on the front is hard-wired to the +5v line, and cannot be speed controlled nor turned off – and that’s a good thing.
The two extruder fans on either side of the print head are wired together, so they act as a single fan. They cannot be controlled independently.
Sorry, I should have been more clear. Yes, I have the Dual V3 on my TAZ 6.
100% agree. Again, I should have been more clear.
I looked up the mainboard and see that there are several fan connectors: Fan 0, Fan 1, Fan 2, 5V Fan
Fan 0 and Fan 1 seem to correspond with Heat 0 and Heat 1. Fan 2 is the case fan and 5V Fan seems to be the fixed common cooler block fan.
The schematic of the mainboard (RAMBO 1.3) shows that each fan is independiantly controlled by the microprocessor.
(MOSFETS section in the middle)
So, the hardware supports individually controllable fans. Even if they were wired together, I would think that I could still control that fan index (and both fans would respond the same), but none of my
M106 P<index> S255
commands yeilded any response at all. I am running 1.1.9.34 (current Lulzbot Cura 3.6.3 firmware). Could this be disabled in the firmware??
Ah - the dual extruder – yeah “details” like that are important!
My post assumed the standard single extruder with the dual fans – it’s not pertinent to your situation, so please ignore it entirely.
