Hi everyone,
We have an older Mini 2 at the library where I work, and we’ve been running into issues when upgrading to the latest version of Cura LE ( 4.13.16) and the machine’s firmware.
After a fresh install of Cura LE and flash of the machine’s firmware, the first print will come out just fine.
The extruder acted up a little on the second print, so it was aborted so we could clean the plate and start again. The issue started when everything started home - Y and Z axis was fine, but on the X axis the extruder assembly just slams into the the left side of the printer and makes a loud grinding noise.
Power cycling does not seem to alleviate the issue at all - I’ve moved the assembly back some, and even tried to push a little down along the Z axis in case and the the autohome reacts the same.
I’d really, really like to avoid rolling back Cura if I can help it because Cura seems to give better print estimates than the v3 iteration (it matters to our kids booking time on the printer) and it starts a little faster on our older laptop.
Any advice?
