Still rebuilding my SL toolhead. Had trouble with reseating the Molex pins for the heater element but think they are now repaired. When I try to preheat the hot end, getting immediate mintemp error. If I measure the resistance at the connector pins for heater and thermistor, what values should I find if they are OK? (both new)
We actually have a guide on testing the heater cartridge and thermistor on our OHAI page linked below.
The bottom will have rough values of what you are looking to see.
What does the screen show for your nozzle temp before trying to heat?
If it’s 0°/0°, the thermistor isn’t connected to the motherboard, or the thermistor has completely failed.
Yep- 0/0° on nozzle. So, it should be some ambient temp value. Must have damaged the thermo somehow. It registers 128 ohms.
