I am having a bit of trouble installing my new board. The instructions are great, however, none of my cables are labeled. They aren’t the same colors either. I have the motors worked out and the end stops with one exception. I found a physical switch for what would be z-min. This connector is a different size than the others. The last connector of the appropriate size is a strange one, it has leads from two separate wire bundles. I suspect this is the z-min. If those two wires are completing a circuit between the nozzle and the metal parts of the plate it would act as a switch. If so, what do I do with the actual switch?
Also, are there any other references to what the other wire colors could be on (perhaps) earlier builds?
I have 5 connections left:
Yellow / Yellow <-- I think this is the bed thermistor
Orange / Orange <-- I think this is the extruder thermistor
Black / White
Black / Yellow
Black / Blue <-- This one is the physical z-min switch
Any help would be appreciated. I did attempt to take pictures prior to removing the old board, but due to the wire density they were less than helpful.
Thanks,
Matthew
