Just got my Taz 6 (first printer ever) so forgive me if this is a stupid question.
I printed a few hollow 15mm³ calibration cubes that are 1.5mm thick
I used a vernier callipers to measure the cubes and found that they are generally between about 0.2mm thicker than modelled (i.e. 15.2mm and 1.7mm thick instead)
I also tried printing several circular holes, and found that their diameters were off as well
I tend to use a 20-40 MM cube to check the X/Y/Z step settings, but it is thus. Bigger calibration cube = better results in calculation.
Example:
40 MM cube model measures 40.2MM on X axis but 40MM on Y. Assumed default firmware settings for steps on axis and flow rate.
40/40.2*100.5 = 100 <- New X axis steps value
So you would update the X axis setting in the configuration menu with the new steps you have just calculated. Y would not need changed as it has no error in size. But if Y did have a size difference you would calculate and update its steps also.
I was having some problems with dimensional accuracy (very bad) on my Taz 6 and finally figured it out. On the y-axis motor the timing pulley gear had slid down a bit and was slightly rubbing on the y-axis motor, causing the y-axis moves to “bind” just a bit. This was causing my prints to look terrible, and overall poor machine performance. I loosened the timing gear on the motor and spaced it according to the OHAI docs, retightened, and sure enough I’m back to getting perfect prints. Hope this helps.
