Hi there,
I have an old lulzbot Mini. It is possible to Change the nema17 Stepper Motor from the x-axis with the shorter Version?
Thanks for your reply
Hi there,
Yes, but.
The qualifier is primarily due to the fact that the shorter motor has less torque, and this will affect a number of things. You’ll probably have to adjust your printer settings (in your slicer if not in the printer firmware settings) – I’d expect that you’ll need to lower the X-axis acceleration to accommodate the lower torque. Lowering the X-axis speed might be reasonable as well, but the top speed of the print head is less important than the acceleration, of course. Note that the current X-axis motor is spec’d to handle the large, heavy dual-extruder, so if you stick with the single-extruder, you might find that you can get away with a rather small decrease to the acceleration setting.
Hi,
I got an aerostruder toolhead. Beside the noise of the x-axis Motor its a really cool printer (with Y-axis dampers and LCD).
OK, it seems to be Not that easy. A Lot of try and error…
Maybe i Just have to buy a new printer which is more silent Out of the Box.
Thanks for your reply!
