PLA bed confusion
I am going to print some PLA and looking in this forum I am confused.
I see postings recommending the use of blue tape on the bed. These posts indicate that the bed should not be heated as the heat affects the tape adhesive. However other posts and the default Cura profiles set the bed to 60.
So is 60 low enough not to affect the tape or should the printing not use tape?
That’s for the TAZ 1-4 which had a bare glass bed. If you have a 5, 6 or mini you don’t need to worry about taoe, set the bed to 60.
