I just finished my first print and noticed at the beginning when the nozzle is close to the bed, the cable chain is being hit by the right rear leveling washer causing a small jump in the print.
I pushed the cable chain up and it stayed put for awhile but gravity is winning.
Any thoughts will be appreciated.
I had the same problem, this seemed to be the quickest and easiest solution, until I find the time to find a more permanent solution
The first link in the cable chain(nearest the X motor) has spread apart slightly and lets the next link pop out of position. Thus letting the chain drop down and hit the washer.
After a couple of prints no more crashing.
I think it just took a temporary sagging set caused by the large foam packing cube.
Thanks for the replies!
