The new PID values were enacted in firmware version 1.1.5.70 that came with Cura 2.6.66. As long as you are using Cura 2.6.69 and the accompanying firmware of 1.1.5.71 then these values will be present in the software.
Afternoon my Aerostruder fell into the serial number range denoted by sticker on back of tool head range.
Unfortunately I wasn’t in the position to be able to arrange return of the head so…
I have replaced the thermistor and the wiring all the way upto the main loom plug with soldered joints I have the latest Cura LE 3 installed and the print head firmware updated through Cura and M coded as per installation instructions.
Problem is I still keep getting creeping temperatures what have I missed ? the replacement thermistor is a genuine E3D V6 thermistor.
Is this a firmware issue do I need to revert back to the last official Cura release 2.6.69 ? to get back on track ?
The Marlin included for all printers will be the latest stable upstream branch of 1.1.8.59 This is what we are currently recommending across all tool heads, and will be worth upgrading to. When installing the new Cura be sure to uninstall previous versions, and clear your cache afterwards. Operating specific instructions can be found here LulzBot | Cura
Hi Brent many thanks for the reply as I mentioned I am running latest version of Cura LE 3 and as I had already swapped out all of the wiring and sensor with neat soldered joints at the loom connector and still having issue I could only guess that the issue I have is software / firmware related.
I just thought if I reverted back to the previous release to see if the problem went as this was originally a thermistor / wiring issue.
Did you check all three connection points, or just the set at the loom? On the Aero thermistor, there will be three sets of pins you will want to check:
I had the same issues after i sent my toolheads back to lulzbot especially with petg, pla and other materials. I ordered silicone socks from matterhackers and so far my thermal runaway problem has not come back yet.
Was ready to make the plunge and use my Christmas “funds” for a Dual Extruder v3… but all of the issues I have been seeing has given me pause. As of December 2018 - have all the issues been worked out? When I search youtube for users who are printing with it - I can only find 1 or two who showed an initial print and they have not posted anything else about it in 6 months. My usage will be exclusively to use water-soluble filament for support structures to help with my more complicated designs. My Lulzbot has run great from DAY 1 so I am little nervous about making an update that could make it less reliable.
The LulzBot Dual Extruder V3 is a fairly solid design. Soluble filaments are iffy at best.
While I printed the test object successfully, I’m under 50% success with other parts when using soluble filament. Most likely I haven’t hit on the right settings yet.
I have approximately the same success rate with two color, same material printing using the Dual Extruder V3 as I have with the Single Extruder.
I don’t think the hardware is responsible for my soluble filament failures. I think my success rate will go up once I get the settings right.
This video (from Lulzbot) shows this as their solution for printing PVA… so I am going to trust their marketing and expect it works as they are showing. My dragon sculptures have grown so complicated this is really the only way to print some of them.
I am experiencing a strange problem. The moment cooling fan kicks off temperature drops resulting thermal runaway error.
If I switch off the fan everything is ok.
I had thermal runaway issues before and fixed it by squeezing the crimps with pliers. This problem started since I switched to Colorfab XT.
Does anyone have a copy of the bulletin with the serial number ranges? It does not appear to be active on the lulzbot support site anymore - the link given by @Nate3D above gives a 404 not found error.
Mine does fall in the S/N Range and I contacted lulzbot support, but they will not support anymore because it is more than four years old and out of production.
@Nate3D - which crimp connector(s) had the problem when you re-crimped? any tip for getting the pins out of the connector? which silicone sleeve fits the aerostruder?
new thermistor seems cheap enough - is the bad crimp isolated to what is contained in the replacement part portion of the wiring?
