What cura setting should I change other than nozzle size when printing with the larger nozzle?
Thansk1
Thansk1
Just that one setting should work fine with the lulzbot configs.
But if you are not changing any other settings, why switch nozzle sizes?
The goal with the larger nozzle is less clogging and faster build times.
So what should I change in the basic config?
The nozzle diameter and layer height is all that’s necessary. The slicing software will use these settings to adjust the rest.
Once you get a few good prints, evaluate and tweak:
