I;ve had my new TAZ 4 for a bit more then two months.
I went through a whole 2Kg spool of Lulzbot black ABS.
I just received a new 5Kg roll of Lulzbot black ABS…
I started a new print… (Cura says it will take 18 hours) some time about 6 hours in the hobbed bolt strips the
the filament and it stops printing…This was using the Lulzbot fine ABS setting with 100% fill.
These are the same settings as 95% of my prints.
So I have several questions…
I changed nothing in settings, height etc… just filament.
Should I have changed something?If so what?
I’ve tried several times to restart and now it won’t even print the first layer, what is the procedure for cleaning the hobbed bolt, do you do it in place or if not how do you remove it?
