I have a question. id there a way to increase the bed test points? I know I could decompile it then change the value and recompile it. I was wondering if there is another work around that people use? I have a print that takes up the whole bed and right now it is less than desirable.
I haven’t played around with it and am not sure if the firmware has limitations but have you looked at:
I have. I was hoping that the devs would know or know if the firmware memory can support 25 to 30 points
According to https://gitlab.com/lulzbot3d/marlin/-/blob/master/Marlin/Configuration.h, the Sidekick 747 uses AUTO_BED_LEVELING_BILINEAR with a 4x4 grid (line 2205 in Configuration.h).
I don’t see any obvious G29 parameters to increase the grid size to 5x5 or 6x6 so you may have to compile your own firmware. I own a TAZ 6 so I’m limited to the 4 corner washers.
You can definitely compile your own firmware to increase the grid points.
In the Configuration.h file, you will need to locate:
#define GRID_MAX_POINTS_X
Here is where you would modify this value per the printer you have.
A value of 3 gives a 3x3 grid, a value of 4 gives a 4x4 grid, and so on.
