Spliting a model into parts that with fit on the plate
So im trying to print a post-it template organizer. There are about 9 different pieces to the file but when I opened the file in the lulzbot edition of cura this is what I get. I obviously need to split it up but have no idea how to go about doing that and Google searches just give me regular cura results or other programs entirely.
Please help
Select each individual object, and use file-> export selected to save as a separate object.
Load each separately for printing after they’ve been separated.
Ok I’ve got the whole export thing but how do I go about selecting a single piece? No matter which part I click they all get the green outline
Cura edition is 4.13.17 if that makes a difference
If it’s not in as separate objects, it’s going to be easier to just download Prusaslicer, Orcaslicer or CAD software and use the cut tool to separate and save the separate models. It’s not a feature that Cura has.
If all the pieces highlight as one object in Cura, the STL is probably one mesh containing separate shells, so Export Selected won’t split it. If your LulzBot Cura build has the Mesh Tools plugin, try Extensions > Mesh Tools > Split model into parts; each shell should then appear as its own object. Otherwise, in PrusaSlicer right-click the object and use Split > To objects—not the cut tool—if the nine pieces are already separate shells. Then arrange and export/print them individually.
