Hello, and thanks as always for your help! Getting frustrated with this one.
So I like to print these low poly pokemon from thingiverse whenever I’ve made a change to my printer to get things re-calibrated, (I give them to my nerdy friends so they don’t just go in the trash). Suddenly though no matter what I try I am getting ridiculous curling around the perimeters (see picture), and nothing I do seems to help… I’ve got a lot of projects I would like to move forward on but until I figure out why this is happening I’m not even going to try… Setup is detailed below:
(In case the images aren’t showing up for whatever reason, the album is here: http://imgur.com/a/bU7VD
Setup details:
Printing with a TAZ5 in an enclosure.
Enclosure ambient temp measured at 45C.
Printing with IC3D (green) ABS.
Bed set to 110C, measured ~106C.
Nozzle @225C (tried multiple temps from 225C-245C).
Cooling fan off.
The pictured print was running at about 60% feed rate, but the outcome is about the same no matter what the feed rate is at.
layer_height = 0.25
wall_thickness = 1.0
retraction_enable = True
solid_layer_thickness = 0.8
fill_density = 25
perimeter_before_infill = True
nozzle_size = 0.5
print_speed = 50
support = None
platform_adhesion = Brim
filament_diameter = 2.89
filament_flow = 100.0
retraction_speed = 10
retraction_amount = 1.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.005
retraction_hop = 0.1
bottom_thickness = 0.40
layer0_width_factor = 125
overlap_dual = 0.15
travel_speed = 150
bottom_layer_speed = 15
infill_speed = 55
solidarea_speed = 45
inset0_speed = 40
insetx_speed = 50
cool_min_layer_time = 15
fan_enabled = False
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 250
fan_full_height = 0.5
fan_speed = 40
fan_speed_max = 60
cool_min_feedrate = 10
cool_head_lift = True
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 45
support_fill_rate = 30
support_xy_distance = 0.7
support_z_distance = 0.05
brim_line_count = 8
