Hey, I purchased a 40mm fan from LulzBot for my TAZ, is there a fan mount design anywhere? I couldn’t find anything on Thingiverse.
Here’s one we have been testing: http://devel.lulzbot.com/TK-0/test_parts/fan_mount/fan_mount.stl
Hi all,
I’ve printed the mount and procured the fan, and am getting ready to try it out. I would be very grateful for any further guidance (acknowledging in advance that this is all experimental). Anyone who has done this or tried to do it: are there any pictures you can share that would confirm my assumptions about how things should be attached? Also, how have people handled getting power from the board to the fan? New wiring all the way through the harness?
Even stories of how it didn’t work would be useful.
I don’t have a fan mounted currently, but it looks like it could be mounted to the x axis carriage on the rear. On my other printers, I have always routed the fan wires through the wiring harness back to the board and used the fan specific connections on the board: http://reprap.org/mediawiki/images/5/5c/Rambo-conn-all.jpg
Thank you for your reply!
So, do you mean a few more parts? Two plugs, one for the RAMBO and the gender-opposite plug for the fan you sell, plus wiring long enough for a run through the harness?
The connectors for the TAZ bed can be found in this post: https://forum.lulzbot.com/t/cooling-pla/158/9 I wired mine in directly with a long lead into the board using these connectors.
OK - thanks!
I’ve printed the fan mount and the orientations I’ve tried either have the fan pointing at the wrong angle or the whole assembly interferes with the X carriage.
Does anyone have a pic of the fan mount installed?
tnx!
g.
I also printed the recommended fan mount and had the same questions, which fell on deaf ears
so I designed my own, file attached, hope it helps
FANmount2_wDuct.stl (1.1 MB)
Can you correct me if I’m wrong: this fan mount http://devel.lulzbot.com/TK-0/test_parts/fan_mount/fan_mount.stl - It doesn’t fit on the back. When put on the right side, the fan can’t aim in the correct direction. When put on the left side, it smashes into the Z-axis threaded rod even without a fan attached. I am guessing you could restrict the X axis travel and still use it, but I think it would have to be by a substantial amount?
In terms of other approaches, @scott has contributed one idea here (thank you!) - are there any others that have come to light?
I’m getting pretty bad PLA print quality on certain prints and seeing some reasons to believe the lack of fan is a factor:
http://www.acraigie.com/3dprinting/cooling-fan-improves-prints/
Very nice!
Thanks.
Yes - thank you!
I also found this:
http://www.thingiverse.com/thing:147966
Will do some experiments and report back.
Someone send me a TAZ and I’ll be happy to custom design you any fan mount you like off it!
What? It was totally worth a shot!
problem with that one and the one that Lulz has a link posted for is that they will crash into the Z motor spring on the right side even before the X axis gets to the edge of the bed.
Alan
OK, I tried it, and it worked out very well. Created a new thread about it here:
http://forum.lulzbot.com/viewtopic.php?uid=194&f=36&t=384&start=0
