I am getting some artifacts on each full layer. Not that apparent on first layer. Also brim looks OK. I wonder is it X or Y axis backlash that is causing it? I did tighten the belts, but might not be up to the “spec”.
Re-calibrate your e-steps/mm. If the issue persists after that, your filament might be slightly over-thick, or expanding slightly when heated. In either case, adjust the flow rate modifier for that filament.
This is instructions for OrcaSlicer’s built-in feature, but you can do similar tests manually to find the best flow for your filament.
