I have one of the first iterations of the Aerostruder. I remember when they first came out, there was an issue where, after the initial layers were printed and the cooling fan kicked on, it caused such a drastic temperature drop that the printer would give a Thermal Error E1 Temperature Runaway. Mine hadn’t had that error, but I almost exclusively print with PLA. The last couple of days I’ve tried printing with Inova 1800 and I can’t get past that temperature drop.
Is Lulzbot still replacing these Aerostruders or am I out in the lurch?
To repeat, I am able to print with PLA with no problems. I only see this issue with higher temperature plastics.
Yes I believe so. The silicone sock is the size and shape of the heater block. I’m pretty sure they’re both the same standard size heater blocks. Some print heads use the larger volcano heater block, the aerostruder is not one of them (unless you bought it from a 3rd party that specifically built it with the volcano heater block).
