Today I printed same 5mm tall small part at extreme corners of plate and back right part is somewhat taller than others. (Images) Reasonable to expect less variation?
Hello mhr_lulzbot,
It sounds like you have an older CURA/firmware version.
For the latest and greatest version of our Cura LulzBot Edition software, as it has all the latest firmware for our printers built in:
Connect to your printer via USB and load the software.
You want to make sure Cura LulzBot Edition is configured for your specific printer and tool head setup before moving forward. In the upper right corner of Cura, you should see your printers name. Please select this, and a drop down menu will appear.
From the drop down menu, you will want to select manage printers and this will open a preferences window.
In the preferences window you want to make sure your printers name is highlighted in blue and to the right, you will see a button that says Upgrade Firmware.
You will want to select that button and then select Automatically upgrade Firmware.
Once completed your printer will reboot itself automatically.
If you need any other assistance please get in touch with our Technical Support folks. They would be happy to help out. You can contact them at Support@LulzBot.com or contact them by phone at +1-970-377-1111
Support is available 7 days a week. Inquires will be answered within one business day.
Monday through Friday: 8:00 a.m. to midnight EST
Saturday and Sunday: 9:00 a.m. to 7:30 p.m EST
We hope this helps,
