Here is a variant of the taller extruder mount designed to work with an E3Dv6 instead of a hexagon. Sourcing an actual 6mm extruder mount plate is a pain in the ass, but I do know of two locations to find them if anyone needs one.
Extruder_-_Spacer.stl (43.6 KB)
taller extruder E3DV6.stl (528 KB)
Why not just print the extruder plate?
Aluminum flexes less than plastic.
In what situation would the hotend flex the plate?
And a 6mm ABS plate at 80-90% infill, sandwiched to the extruder… tough to flex.
Extremely high speed printing. At lower speeds it wouldn’t flex the plate. At 400mm/s and above, it would be a concern.
Hmm… ok. I don’t think i’d ever set the speed that high, but i guess its possible.
Filastruder has them…
Looks like they just have the plastic one or the aluminum bulldog mount.
