Hello,
This is a mixture design of the old dual and the Javelin. All objects were altered to a degree, keeping the proper registrations for lowerBrackets, flexPlate, xCarriage mounts, and hexMount. The hexMount is the only stock object.
I use Inventor for most of my modeling now. I have spent a good many years with AutoCAD, Maya, 3ds before it was 3d max, and I love Blender, but, you will have to reverse engineer everything you modeled in all Previous programs except AutoCAD. Inventor is accurate and expensive. Solid works is not familiar to me.
Interpolated curves and cv curves with geometric dimensioning and tolerances are very important. Maybe not so much if you are a game forum hack, but if you have had a proper education in GDT YOU WOULD KNOW THIS. Non Uniform Rational B Splines and the good ole fashion OD AND ID are a good place to start if you really want to Model across entertainment or industrial CAD/CAM.
There are flaws in some of the objects on the DevSite. Non manifold geometry was found on more than one model.
And look for non perpendicular profiles on important components.
This extruder is working great!!!, and I put a more powerful fan for the rear extruder. At first the readings from the hotend were a little low, Heat creep is not a problem on this one!!!.
All parts were printed in ABS and polyCARBONATE. Anything over 12 MM height (PC)SEEMS TO PULL and contract with great strength if you are not heating the environment and atmosphere up to the glass transition temperature. You will need a strong bed adhesive, and truthfully that will not help without a second heater in the enclosure.
I am not a Troll, but I will not give away everything on my mind or give away all of the things that are creatively mine.
We have to make a living some how?Right?
The young man races to the water’s edge to beat the old man to a meal. The old man watches, but does not move a muscle. He knows there are crocodiles awaiting the young fool and he will be picked clean like the one before him.
Ideas are worth something. You need to protect them. As well, share the road to them.
