Having a bear of a time with this. Thanks for any help.
I take it you followed the guidelines from Taulman. Search PET or PETG… there was a discussion a while back.
What issues are you having?
Yup, Also talked to Makergeeks directly. I started a new thread about it. Basically, prints are failing anywhere from second layer to 50%. Seems to be an issue with retraction. Adjusted tension many times and just get deeper grinding with same fail.
Hi Peter, are you still having issues? I recently printed T-Glass on my mini and here are the settings I used.
Nozzle Diameter = .6mm (actual physical size is .5mm)
Extrusion Multiplier = 1.0
Retraction Distance 1.5
Retraction Speed 1800mm/min
Layer Height = .3mm (I was going for clarity)
First Layer Settings:
135%
85%
70%
Temps = 240 Nozzle/60 Bed
Cooling:
Layer 2 - Fan on @ 35%
Speeds:
1200mm/min print speed
90%
90%
75%
4800 mm/min
1000 mm/min
Speed Overrides:
Check box, 15 seconds, 40%
Some roses I recently completed. The Super Rose from Thingiverse
Chris,
Gorgeous prints. Thanks for sharing your settings.
Sweet. Will try them out. Thanks a bunch! And yes, really nice prints!
Cheers, appreciate it. It was an absolute dream to print with so I am surprised you are having issues. Id be curious to see what settings you were using though Peter?
