During a move from one side of my printing table to another, I bumped the PSU with the Y axis stepper motor. This light tap caused the motor bracket to delaminate into two pieces. I am going to try some ABS gluing later today to fix the issue. This occurred after a few months of use and over 20lbs of plastic being ran through the machine.
Here are some shots of it glued together. The white residue is actually a grey that is the result of the black ABS glue being applied too thick. I decided to paint the whole bracket to help fuse the outer layers better.
adding 2 extra mounting bolts certainly would (behind, or under the motor, mounting the bracket to the aluminum)…so it is not trying to bend on the mounting holes.
or you could print 2 of them and glue them together, back to back to get the same affect
