I don’t know what the problem is but my Lulzbot Mini will not auto level and clean if in Cura I go to Expert and click switch to full settings. Then I use the basic one. When I press print, my printer will skip the normal routine and start printing. But when it prints it is printing in the air. (4mm above the bed) Everything works perfectly if I print with the quick print settings. Please help me as soon as possible. Thanks
Have you tried loading a profile from here?
https://www.lulzbot.com/support/mini-cura-profiles
Thank you!
You must load the posted profiles anytime you switch to expert mode. It’s what tells the printer to auto level and nozzle clean.
