I usually create my STL files in Autodesk Inventor. Whenever I do this in order to get the file the actual size I need to scale it up 10x. Does anyone know why this is happening and how I could fix it so I don’t have to scale it up?
I suggest going into the options when saving the STL and select the units to be mm from cm.
Here’s some pics to help!
Thats exactly what you are running into.
Thanks everyone that worked. I just needed to change it in the options menu from centimeters to millimeters
