I have a TAZ 5 and bought it last year when it came default with the .35mm nozzle end. Can you buy a 0.5mm nozzle end? I only see the whole extruder assembly on sale. Thanks!
Lulzbot doesn’t sell them directly. You can buy a refurbished one from I-T-W.com, or a new hexagon or compatable E3DV6 nozzle from any online retailer. Matterhackers has some nice ones there.
Thanks for the quick reply! If I were to purchase an E3Dv6 end would I be able to just screw it on and start using it? Or is there mods needed. I know I will have to change slicer settings. Below is a link to what I am looking at. Thanks.
https://www.matterhackers.com/store/printer-accessories/e3d-v6-extra-nozzle-3.00mm-x-0.50mm
Assuming your printer is out of warranty you can just pop it in and start using it. You have to adjust the slicer nozzle setting if you go with a different size, and you’ll want to look up the proper installation procedure.
If your printer is still under warranty, apparently unscrewing a nozzle will void your warranty, which I think is less than ideal policy. Its not exactly rocket surgery.
Thanks! We have plenty of new OE 3mm .5 .4 and .35 nozzles as well http://i-t-w.com/parts/hexagon-nozzle
