I have a problem with my TAZ 6. I completely broke the nozzle and the thread stuck into the hotend.
The meterial of choice was CF-ABS.
There is a lot out there for the TAZ 5 but I need to have some recommendations for the TAZ 6 with a Single extruder v. 2.1.
LulzBot is not selling the stock extruder at the moment, so I have to make the changes by myself.
So my questions now are:
I can answer one question. The E3D nozzles do fit the Hexagon hotend. They are a little longer so you might need to adjust the nozzle wipe gcode if the nozzle tears up the wiper pad to quickly. I am running a V6 nozzle on my Mini which has a similar nozzle wipe feature and I have not needed to adjust the wipe gcode. It works great.
There is a known issue with the Hexagon nozzles fracturing. Lulzbot might replace the broken part under warranty, if you wanted to go that route.
If the nozzle is longer then you may encounter issues during a probe fail sequence, where the firmware settings are used to do an additional wipe. That wipe height is not set in the gcode.
I believe that when the nozzle touches the switch and activates the contacts, that is taken as Z=0 so the longer nozzle barrel length is not noticed. YMMV.
We don’t recommend replacing the nozzles, as we have found it quite common that damage will happen to the hot end or printer. (Sheared nozzles, broken thermistor/heater cartridge, break the seal between heater block and threaded extension, damage to the electronics board)
Any damage done while changing nozzles would not be covered under your warranty.
