What are the wiring connectors called that are used for supplying power to the extruder motor, hotend, parts fan and the small hotend fan that comes with the TAZ 5, and where can I find them on line. On my TAZ 5 there 4 seperate connectors 2 large (4 wire) and 2 small (2 wire) connectors.
There are two possible connector types for the Taz 5. The early style ones from Digikey are the following part numbers (do a search on the WMxxx-ND numbers, they should come up.)
4 position connector
WM2902-ND 0050579404 CONN HOUSING 4POS female W/LATCH
WM2535-ND 0701070003 CONN HOUSING MALE 4POS
2 position connector
WM2900-ND 0050579402 CONN HOUSING 2POS female W/LATCH
WM2533-ND 0701070001 CONN HOUSING MALE 2POS
Pins for both 2 position or 4 position connectors
WM4593-ND 0016020098 CONN TERM FEMALE 24-30AWG 30GOLD
WM2567-ND 0016020117 CONN TERM MALE 22-24AWG GOLD
I’ve never ordered any of the newer pin style ones, you would need to get them from the bill of materials (BOM) found in download.lulzbot.com
