Just experimenting with Cura LE 4.13.4 attached via USB to Mini v1, to try to resolve an unexpected issue with printing temperature (it was trying to print at 250C under Cura 3.6.36 and 3.6.40, and I can’t find where that temperature is coming from).
Trying to update firmware in v4.13. Click on Update Firmware, a progress bar opens but there’s never any progress, even after many minutes.
How can I update the firmware? And if I do that, with the Mini still work with Cura LE v 3…40?
When I try to print a small simple test piece, I click Start Print, and nothing happens.
The wrong printing temperature is displayed (240C) also the wrong Build Plate temperature (110C) whereas the material selected has 230C and 105C for these values, and the reported hot end and build plate actual temperatures are showing at 0C and 1C respectively, and not changing at all after I click Start Print.
Am I doing something wrong? Do I need to do anything further to set up the Mini under v 4.13? It seems to be a supported printer, and is showing as Connected, via Com5.
