I’ve been running the latest versions of Cura on my two modern Macs without issue. I have an older Mac running 10.11 as well but can’t get the latest Cura (3.6.21) to launch on it. I get a dialog from the GUI application which says simply “cura-lulzbot Error” and has buttons to either open Console.app or to Terminate.
The same happens when launching the x86 binary from the Terminal from inside the .app bundle.
Cura LE 3.6.21 says it should be compatible with macOS 10.10 or newer … so it seems like it should run.
Did this mac ever have a previous version of Cura installed? I’m wondering if there are old files that didn’t get cleaned out.
I’ve had issues upgrading … so I used an AppCleaner (which finds all the extra files related to the application … not just the application itself) and that resolved the issue on my mac. (Specifically I used this: https://nektony.com/mac-app-cleaner – it’s free, but they’ll try to sell you on upgrading to their pro version.)
Thanks for the suggestion. No, I’ve never run it on this Mac before. I’m also familiar with all the preferences, application support, caches, etc. that Mac apps can leave as I am a Mac developer. Still, I both checked manually for any files on the system referencing Cura, as well as used a utility that can do this. Because Cura is written as a cross-platform app, though, and not a native Mac app (using a Python framework call Uranium), it doesn’t store things in the typical way that Mac apps do. Still, no luck on that front.
I am having the same issue with 3.6.35 on an older mac running 10.13.6 (high Sierra.
Blockquote
Blockquote
The download file was in .zip format. This is not normal for app distribution on macs in my experience and made me suspect an issue caused (long ago) by Windows based zip utilities. If that were the case I would expect the same issue on all macs. At the moment, I don’t have a newer mac to try the same download. I stumbled upon a directory in an old lulzbot ftp tree containing additional files to be added to the mac release after 3.6.20 (or so). Maybe will g look into that.
I would love to know if 3.6.35 or newer works on any mac.
