I would like to know what the difference there is between the different (for example) PLA material?
I tried to look into the Cura installation 20.01 and can not find the difference between (for example)
PLA (Verbatim) and PLA (eSun).
So in short what is the different characteristics parameters between the different PLAs?
After you open a profile, switch to “full settings” from the expert menu to see all of the individual parameters. Accept the prompt to copy the profile settings that pops up.
I did as Steve suggested and I still can not see any difference between the PLA Verbatim and PLA eSun!
Look at screenshots I made … So what it the difference and where can I find it?
There are no differences between those two configs, at least for the standard quality profile.
eSun
[profile]
layer_height = 0.25
wall_thickness = 1
retraction_enable = True
solid_layer_thickness = 1
fill_density = 20
perimeter_before_infill = True
nozzle_size = 0.5
print_speed = 50
print_temperature = 0
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 0
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
retraction_speed = 10
retraction_amount = 1.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.005
retraction_hop = 0.1
bottom_thickness = 0.425
layer0_width_factor = 125
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 175
bottom_layer_speed = 15
infill_speed = 40
solidarea_speed = 30
inset0_speed = 30
insetx_speed = 35
cool_min_layer_time = 20
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 250
fan_full_height = 0.5
fan_speed = 75
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 45
support_fill_rate = 30
support_xy_distance = 0.7
support_z_distance = 0.05
spiralize = False
simple_mode = False
brim_line_count = 10
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.5
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
simplemodesettings =
simplemodeprofile = Standard
simplemodematerial = PLA
simplemodematerialtype = Beginner
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed};move the platform down 15mm
G92 E0 ; zero the extruded length
G1 F200 E0 ; extrude 3mm of feed stock
G92 E0 ; zero the extruded length again
G1 F{travel_speed} ; set travel speed
M203 X192 Y208 Z3 ; speed limits
M117 Printing... ; send message to LCD
end.gcode = M400
M104 S0 ; hotend off
M140 S0 ; heated bed heater off (if you have it)
M107 ; fans off
G91 ; relative positioning
G1 E-1 F300 ; retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F3000 ; move Z up a bit and retract filament even more
G90 ; absolute positioning
G1 X0 Y250 ; move to cooling position
M84 ; steppers off
M117 TAZ Ready.
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
T1 ;Switch to the 2nd extruder
G92 E0 ;zero the extruded length
G1 F200 E10 ;extrude 10mm of feed stock
G92 E0 ;zero the extruded length again
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 2nd extruder
G1 F{travel_speed}
M117 Printing...
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
T2 ;Switch to the 3th extruder
G1 F{travel_speed}
M117 Printing...
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
Village Plastics
[profile]
layer_height = 0.25
wall_thickness = 1
fill_density = 20
nozzle_size = 0.5
print_speed = 50
support = None
wipe_tower = False
ooze_shield = False
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 175
infill_speed = 40
inset0_speed = 30
insetx_speed = 35
fan_enabled = True
skirt_gap = 3.0
fan_speed = 75
fan_speed_max = 100
solid_top = True
solid_bottom = True
fill_overlap = 15
support_angle = 45
spiralize = False
simple_mode = False
raft_margin = 5.0
raft_airgap = 0.5
plugin_config =
[alterations]
G21 ;metric values
end.gcode = M400
M107 ; fans off
M84 ; steppers off
M117 TAZ Ready.
;{profile_string}
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
No difference in profile, but a massive difference in quality. eSun has had tolerance problems for a long time - I use their HIPS to print boxes for my board game parts, and for that it’s fine (especially at the close out price!), but I’ve given up on it for everything else. I’ve heard similar tolerance problems with their PLA too.
I usually buy PLA filaments from Innofil3D web shop. Actually I have used PLA filament while I was doing a project in my college. And the college provided PLA filaments of this company. It was nice experience at that time. It was a small project related to the toys and I completed it successfully.
