Taz 6 - Recently updated cura to latest, 3.6.37.
When I run the gcode for a model made with 3.6.37, the tool head does not lift after wiping and drags to tool head across the wipe pad holder as it moves to the home position before starting the probing.
Update your firmware also. 3.6.37 is designed around 2.0.9.0.12 or newer.
Thank you for the quick reply!
If I update the firmware, will I have to recreate gcode for all my other models that I print on a regular basis?
Yes, the startup gcode created with previous versions of CuraLE was made for that firmware, so you need to re-slice those models.
Thanks again for quick reply and the help!
Problem solved.
t
