Which bolts? The extruder mounting bolt that goes through the new little clip that holds the heatsink fan?
I wonder if the fan frame was physically stressed somehow and it wasn’t spinning at normal speed and you weren’t getting the cooling you needed on the back extruder?
I tried to print the shroud and the clip with my FlexyDually. It has 0.6mm nozzles which are just too big for the model’s thin walls. I tried to adjust my extrusion width to 0.5mm in my slicer but it just resulted in horrible quality and I still have holes in the walls. Are the original CAD files available so I could thicken the walls a bit? I can use the STL’s as well but it is always a hassle.
I had the same problem printing with the defaults for the TAZ 6 which has a 0.5 nozzle and defaults to 0.6 extrusion. I was able to get a usable print with lots of tweaking but the prints were not great by any means.
I converted the STL to solid in FreeCAD and I try to thicken it a bit. If it works I will upload the file here. It will take a week for my fans to arrive so I can assemble the thing. If KelVarnson still has the original CAD files those would be a lot cleaner to modify.
I’ve included step files here for the shroud (Version 2) and the two clips (Version 2 and Version 3). The version 2 clip is symmetrical and reversible, but requires a standoff under it for spacing. The version 3 clip is non-symmetrical, so you can only load it on one side of the fan. However, it eliminates the need for a spacer underneath.
For what it’s worth, I printed my shrouds and clips in ABS, using my home printer, which is a Sourceforge Creator. I think it might have a 0.25mm nozzle, not sure.
That explains why you were able to print the original files just fine.
Finally I got my fans. Everything seemed to line up nicely but I realized I don’t have small enough screws. Hopefully I can get it together tomorrow.
I posted the stl files in the first post when I started the thread. It’s two files, one for the shroud, and one for the clip that attaches the fan and the shroud to the print head.
Note that the original clip design is symmetrical, it can be used on either side of the fan. In the third post I added an stl file for a revised clip design, which was slightly beefier and eliminated the need for a standoff. However, this results in it only being usable on one side of the fan. This approach works for the dual head, but I am not sure whether or not it will work on a single head.
I’m about to undertake this upgrade myself. Just to be sure I’m not missing anything, do I only need these parts?
20mm x 8mm 5v fan x2
M4 x 35mm bolt x2
I replaced one of the extruder bolts, the one underneath the stepper motor, using an M4 x 35mm machine screw with a 7mm hex head. This also solves the annoying problem of trying to hold the extruder mounting nut in place during reassembly. Underneath the fan mounting clip is a 6mm tall spacer with a 4mm clearance hole. The screw comes down through the spacer, through the clip, and another nut goes on the end to hold it all together and hold the extruder down
Could you point out exactly what screws you’re talking about here? I’m looking at the photos and I don’t quite see how you bolted the 3D printed clip in.
No, that’s the part that blows directly onto the print itself to cool it. This attaches next to the heatsink to prevent heat creep. I just added it to mine and before where it’d struggle to handle a 30 minute print it now runs at least two hours just fine.
I’ve printed these parts but there is a hole where the fan attaches to the shroud. I’ve looked at the .stp file and there’s nothing there, it doesn’t show when you look at the part in Cura normal view, but if you look at the layers, you can see the hole.
I’ve sliced the part with CuraLE 2.6.69, CuraLE alpha 3.2.14, and Simplify3D and they all show a hole in the print. I’m guessing the settings are wrong but I’m not sure what to change. Can anyone help?
I’ve spent a little less than 100 hours reviving an old Taz 5 with Dual Extruder V2 to print PLA for my wife’s project. Most of that was struggling with what I eventually learned was heat creep.
This was a major piece of the fix, thank you so much! I was really despairing for a while there, and I understand getting this particular extruder to work well with PLA is not at all a sure thing.
I also had to make some other changes to fix the heat creep and bed adhesion.
Adhesion: I’m using one of those magnetic flexible bed plates, and I’m running the hotends at 220 and bed at 70, all needed to get first layer adhesion. Also, Cura was starting prints by placing the shortest segments down first, little dots; even after my improvements, these would sometimes get dragged around and mess up the print. Setting “wall ordering” to “outside to inside” fixed that, so now the longer segments are printed first, and dots later.
Heat creep: Even with this mod, with those higher temps heat creep is still a problem. Fixed by putting a fan next to the printer, not blowing directly on it, but just to keep the air circulating. The theory is the hotend cooler fans can pull in cool air. I’ll replace that with something more purpose-built later, but that’s what got everything finally working.
