We designed our toolhead mount to place the Titan Aero nozzle at the same X/Y/Z location as the factory. Initial testing indicates that our solution to the false Z min trigger issue with the Foxglove Minis is working- we place a .01uF cap ( manuf part # A103K15X7RF5TAA available at mouser, digikey, etc )across the sense and ground lines. This should not affect the Gladiolas as the sense is just another ground on those machines.
With a bit more testing we expect to launch the Mini E3D Titan Aero toolhead shortly!
Hopefully LulzBot engineering notices this post. Unless you test on a Foxglove, you won’t see this problem until Foxglove owners start buying the Titan Aero toolhead you’re developing. The current wiring diagram on devel doesn’t show a cap.
Blog post update on the Mini Titan Aero (video includes Molly the 3D Printer Dog!) https://itworks3d.com/e3d-titan-aero-toolhead-lulzbot-mini-preview/
Where can i get the mount to print for the Titan Aero on a mini I already have the extruder kit from IT-Works ?
THanks
Hadn’t had much luck installing the caps myself, so patiently waiting on your solution.
