Has anyone built an enclosure with a sliding front door instead of a hinged one? I have my Taz on a large shelf and have the horizontal space for a sliding door and it seems it would be simpler and also easier to work on your Taz (or remove it) since you could just easily slide the door all of the way out and remove it for a large access? Everything I’m seeing is using a swinging door and it seems to cause issues with gaps and alignment with long term use.
