Hi everyone,
I am working with Taz 4. my printer is displaying ‘Err MinTemp’. The result in a situation whereby the machine heated the bed but refuses to print on the bed. Kindly help.
You probably have a thermistor unplugged or it has a broken wire. Check your connections.
If you are still running a budaschnozzle, if I remember correctly, it was possible to swap the heater resistor and thermistor connectors causing that exact error.
