I can’t find firmware files for Workhorse HE 05 and Dual Ext V3 for the workhorse.
Will the TAZ 6 files be the same?
I want to use it to to be able to flash from Octoprint.
After installing CuraLE 3.6.22, the folder C:\Program Files (x86)\cura-lulzbot 3.6\resources\firmware contains:
You could also check out the gitlab https://gitlab.com/lulzbot3d/cura-le/cura-lulzbot
Thanks b-morgan and rhenderson.
That solved one problem, I’ll start a new thread for the next.
Edit:
I adjusted the plugin settings to below and now all is good!!
