I am running filkemp (filament express) PLA. I quite like it. I extrude at 250c/ & 70mm/s (which sounds hot for PLA, but this is a special blend and they reccomend that temp at 70mm/s). I have a .5mm nozzle and am extruding at .61mm.
My issue is that if I run the fan at anything over 55% the hotend starts to cool off - down into the 230s.
Is this to be expected? Is it possible that this filament is a real ‘heatsink’ and that the volume I am pusing through at this speed is just too much cooling for the hotend to handle? Or, do I have a problem?
Thank you!!
J
