How do I season a smooth sheet
What supplies do I need or do I just wash the bed
I used factory settings
It is green filament the sheet is fresh out of the box
I also cleared a significant amount of filament in the extruder & extruder for Load for PLA was 160•c for leveling at -1.200 mm & auto load
Feel free to correct anything that will help
PEI doesn’t need any special surface prep, just clean it with dishwashing soap to get any residual oils off it. If you still have adhesion issues, a little bit of gluestick can help, but nothing beats a proper bed leveling for first layer adhesion.
personally I like Magigoo i am not Stranger to 3dprinting i got my first 3d printer for Christmas 2015 it was a lulzbot mini from loveland before it was bought off i do not remember a lot about the printer it is retired i still have the old flextruder in the box
@TimPostma - You need to adjust your Z-offset. An offset of -1.20mm is roughly what it should be if you had glass and with a magnet bed will shift your offset closer to +0.50mm.
i tried tha but i will go to a 3dp place in the 5th month
i was able to have a technician fix it yes Z-offset was a part but so was flow and under debris thank you everyone
