Hi im quite new to Lulzbot i recently got Taz pro and have problems with leveling. Software is upgraded but when try leveling sequence nozzle is of the corner pad is too much forward and slightly to the left off the pad ( front right pad) im not too sure which extruder is fitted recently is 1.75 mm with bondtech drive, I have dual extruder but dont have 3 mm filament at the moment. Is any way to change coordinates so the nozzle can hit the target ? I realised when nozzle is wiping on the right pad is off around 5 mm so is mowing between pad and bed but not on the pad. Any help will be appreciated.
It sounds like you don’t have the proper firmware for the toolhead you’re using
Is it the pro dual:
You’d load “C:\Program Files\CuraLE 4.13\resources\firmware\Pro\Marlin_TAZPro_Universal_DualExtruder_2.1.3.0.21_c3bfdcf.bin” firmware.
Or the twin nebula 1.75?
For this, you’ll load the firmware “C:\Program Files\CuraLE 4.13\resources\firmware\Pro\Marlin_TAZPro_Galaxy_DualExtruder_2.1.3.0.21_c3bfdcf.bin”
