I recently purchased my third Lulzbot, Mini 2, and have only been able to have about 5 successful prints. Other than that it is failing to do an initial probe. The nozzle crashes into the first washer and starts the rewipe process.
It does this over and over until the printer crashes. I get the same issue when I switch to a SL toolhead. I have replaced my wiping pad and have checked my washes and their connections. I have checked the tool head connections but cannot get the thing to probe correctly.
Waiting on support but have better hopes with the forum.
The most common answer to this problem is, “is your nozzle clean?’” And… that’s usually the answer. I think the easiest method is to heat up your nozzle temperature to printing temperature and wipe it down thoroughly with a dry rag or dry paper towel. Heat up the nozzle as said then select cool down (or turn off the power to the printer) and continue to wipe until the nozzle cools down to at least 160C, at this temp filament is no longer melting and oozing out. If you heat up, wipe and think you’re done, you’re wrong, oozing filament will get ya! It also won’t hurt to scrub the nozzle with a stiff bristle brush like a toothbrush or one with brass bristles. Also, of very extreme importance, don’t clean your nozzle with a metallic brush with the power on, else you’ll blow one of the micro fuses and then have to deal with replacing that.
Had a similar issue. Can you connect to the printer, home it, check the status of endstops using M119 paying close attention to Z_MIN. Then move the toolhead down so that it touches the probe and check M119 again. If it still says OPEN then it’s not reading properly. With the parts touching, turn off the printer and check continuity between top of head and bed plate with a multimeter.
I had this same issue and changing the head fixed it for a while. After using the new head for a few prints Z_MIN went into an always TRIGGERED state and was autoleveling in the air. Had to fix it in firmware:
I dug out my multi-meter and I got a big fat zero when it was turned on. The Z_Min has stayed open both at home and touching a washer. There is continuity between my nozzle and washer when it is touching.
Should be ordering a new board? I bought this thing on Jan 2.
You can do some continuity checks with your multimeter. I was in my Taz 6 case earlier today troubleshooting a Y axis issue and accidently unplugged the cable for the self leveling. I did a continuity check of the wires which lead me to the open lead. First I checked from the washer to the bed connection (it’s on the underside of the bed)
Then trace that wire back to the cas as best you can and see if you can locate it. In my case the lead was not attached to the board and once I re-attached it it was right as rain. I have tried to look at the instructions for your machine but without one in front of me its hard to understand. Here are the board instructions. You may have better luck with the machine in front of you.
You can also check from the hot end back. The term in the hot end instructions appears to be the zero sense ground wire on pin 8 (If I interpreted correctly). You can make sure the hot end and the pin have continuity and again trace it back into the case.
Hope this helps and you find a loose connector like I did. A quick plug in and I was up and going in no time. Good luck!
Thank you both for the input, as it helped me track down the multiple issues that have become present in the last few days.
The Z-Min Pin (Green) was twisted and barely into the connector. But while having the box open and checking continuity I found that the Zero Sense pin was in the wrong slot (obvious issue)
What is crazy is how the pin would work sometimes, given the amount of vibration was happening.
The Mini 2 probing failure on first washer thing has raised its ugly head for me too and not finding the problem.
1.) the nozzle and the four bed washers are super clean. Certain.
Powered on…
2.) There is continuity between the nozzle and the back left washer.
3.) There is 4.75v between nozzle and back left washer.
4.) There is continuity between the back left washer and all other washers + the nut below the bed.
5.) stripped back the insulation and soldered the brown wire to lug connector as suggested here.
Powered off…
6.) There is not a continuous continuity signal between nozzle and back left washer. (single beep. not continuous)
With the nozzle touching the back left washer (and powered off) open up the box and find the Z-Min port on the board. There should be a green and a white wire. Check for continuity by touching those two wires. Doing this will verify that there is a complete circuit.
I found that my ground pin was barely pushed in and twisted out so would only sometimes create a circuit.
I disconnected the Z-min plug and find no continuity between the two male pins on the board OR the female pins of the white/green plug.
Also notice that a green/green plug that is attached to the frame on the other end is not plugged in?
In the power chamber there are four other wire pairs with plugs that are bundled and unused. I snipped one off and spliced it onto the white/green pair as shown below. Probes fine now.
