Hi,
I’m trying to print with the Lulzbot mini, but can’t get past the nozzle wipe. The nozzle goes across and back on the wiper about 6 times and then presses down on the left hand side of the wiper, I presume this probe should be on the washers, but it does not seem to initiate the auto level sequence. Repeats this twice and then disconnects. Notice by the log below it says bed leveling off. Could that be part of the problem?
ScottW
April 18, 2021, 9:49pm
2
Make sure you have the correct firmware loaded – Mini with Standard extruder. Either just reload it – or you may be able to check by sending an M115 command, which should respond with the firmware build (including the printer model and extruder model).
Check that your startup script has the proper commands… After wiping, it should raise the extruder, home x and y, move away from the endstop slightly, set acceleration, and then issue the G29 to start the auto-level probing.
Vlad1
November 8, 2022, 4:03pm
3
bmclean,
I’m having the same issue. Can you relay the solution if you had one? I tried reloading the firmware to no avail. I’m worried I’m stuck with a $1000 hunk of shit.
Thank you in advance.
What firmware and software versions are you currently using?
same issue. here is debug file. I wonder if the M206 command I inserted is wrong place?59.00 E:-30.00 Count X:0 Y:18794 Z:251200
< [11:15:41] X:52.00 Y:178.00 Z:-2.13 E:-30.00 Count X:0 Y:18794 Z:251200
< [11:15:43] echo:busy: processing
< [11:15:45] echo:busy: processing
< [11:15:47] echo:busy: processing
< [11:15:49] echo:busy: processing
< [11:15:51] echo:busy: processing
< [11:15:53] echo:busy: processing
< [11:15:55] echo:busy: processing
< [11:15:57] echo:busy: processing
< [11:15:59] echo:busy: processing
< [11:16:01] echo:busy: processing
< [11:16:03] echo:busy: processing
< [11:16:06] echo:busy: processing
< [11:16:09] echo:busy: processing
< [11:16:11] echo:busy: processing
< [11:16:13] echo:busy: processing
< [11:16:15] echo:busy: processing
< [11:16:17] echo:busy: processing
< [11:16:19] echo:busy: processing
< [11:16:21] echo:busy: processing
< [11:16:23] echo:busy: processing
< [11:16:25] echo:busy: processing
< [11:16:27] echo:busy: processing
< [11:16:29] echo:busy: processing
< [11:16:31] echo:busy: processing
< [11:16:33] echo:busy: processing
< [11:16:35] echo:busy: processing
< [11:16:37] echo:busy: processing
< [11:16:39] echo:busy: processing
< [11:16:41] echo:busy: processing
< [11:16:43] echo:busy: processing
< [11:16:45] echo:busy: processing
< [11:16:47] echo:busy: processing
< [11:16:49] echo:busy: processing
< [11:16:51] echo:busy: processing
< [11:16:53] echo:busy: processing
< [11:16:55] echo:busy: processing
< [11:16:57] echo:busy: processing
< [11:16:59] echo:busy: processing
< [11:17:01] echo:busy: processing
< [11:17:03] echo:busy: processing
< [11:17:05] echo:busy: processing
< [11:17:07] echo:busy: processing
< [11:17:09] echo:busy: processing
< [11:17:11] echo:busy: processing
< [11:17:13] echo:busy: processing
< [11:17:15] echo:busy: processing
< [11:17:17] echo:busy: processing
< [11:17:19] echo:busy: processing
< [11:17:21] echo:busy: processing
< [11:17:23] echo:busy: processing
< [11:17:25] echo:busy: processing
< [11:17:27] echo:busy: processing
< [11:17:29] echo:busy: processing
< [11:17:31] echo:busy: processing
< [11:17:33] echo:busy: processing
< [11:17:35] echo:busy: processing
< [11:17:37] echo:busy: processing
< [11:17:39] echo:busy: processing
< [11:17:41] echo:busy: processing
< [11:17:43] echo:busy: processing
< [11:17:45] echo:busy: processing
< [11:17:47] echo:busy: processing
< [11:17:49] echo:busy: processing
< [11:17:51] echo:busy: processing
< [11:17:53] echo:busy: processing
< [11:17:55] echo:busy: processing
< [11:17:57] echo:busy: processing
< [11:17:59] echo:busy: processing
< [11:18:01] echo:busy: processing
< [11:18:03] echo:busy: processing
< [11:18:05] echo:busy: processing
< [11:18:07] echo:busy: processing
< [11:18:09] echo:busy: processing
< [11:18:11] echo:busy: processing
< [11:18:13] echo:busy: processing
< [11:18:15] echo:busy: processing
< [11:18:17] echo:busy: processing
< [11:18:19] echo:busy: processing
< [11:18:21] echo:busy: processing
< [11:18:23] echo:busy: processing
< [11:18:25] echo:busy: processing
< [11:18:27] echo:busy: processing
< [11:18:29] echo:busy: processing
< [11:18:31] echo:busy: processing
< [11:18:33] echo:busy: processing
< [11:18:34] echo:endstops hit: Y:3.36
< [11:18:36] echo:busy: processing
< [11:18:38] echo:busy: processing
< [11:18:40] echo:busy: processing
< [11:18:41] echo:endstops hit: Y:190.15
< [11:18:43] echo:busy: processing
< [11:18:45] echo:busy: processing
< [11:18:47] echo:busy: processing
< [11:18:49] echo:busy: processing
< [11:18:51] echo:busy: processing
< [11:18:53] echo:busy: processing
< [11:18:55] echo:busy: processing
< [11:18:57] echo:busy: processing
< [11:18:59] echo:busy: processing
< [11:19:06] echo:busy: processing
< [11:19:08] echo:busy: processing
< [11:19:10] echo:busy: processing
< [11:19:12] echo:busy: processing
< [11:19:14] echo:busy: processing
< [11:19:16] echo:busy: processing
< [11:19:17] X:11.00 Y:183.00 Z:10.00 E:-30.00 Count X:503 Y:18593 Z:16200
< [11:19:20] echo:busy: processing
< [11:19:22] echo:busy: processing
< [11:19:23] Error:Probing failed
< [11:19:23] X:3.00 Y:159.00 Z:0.88 E:-30.00 Count X:-302 Y:16181 Z:1600
< [11:19:24] echo:busy: processing
< [11:19:26] echo:busy: processing
< [11:19:28] echo:busy: proc
