LulzBot Taz Pro- M175 v1 Probe Issue
Hello!
I need help with my printer, in the topic I include the tool head.
I tried to upgrade the firmware in different versions and I Obtained the same result. And changed the nozzle too.
The auto-leveling failed, but when I edit the backslash and use probe mesh all it’s okay but when I send the design to print the set up fail in the first point, I though the problem was the Y-axis but I cleaned and move and it’s okay.
Could you help me whit this problem?
What you do is under new printer on lulzbot cuts
Second what year or production is your 3DPrinter & toolhead?
If you’re running a M175v1, offsets are going to be off. There hasn’t been corrections for the nozzle location of that one for a while.
Also, this reads like word salad of 3D printing terms with a bad GPT. Was it translated, or just the output from a bot?
Correct me if im wrong but the M175v1 is a single extruder so you would need to a way to deal with the Taz pro which is because the Taz pro is a duel extruder then make sure the toolhead chamber is ready then wash the bed is a good start but I would recommend if you absolutely want a ton of adhesion without glue I would recommend getting a new textured sheet because texture adds adhesive capabilities
