When the mini finishes a print the bed lowers to 50C and stays there. Often, a print will finish after I go to bed so, the printer is setting there warm most of the night. Has this been done for a reason or is it a mistake in the configuration file?
I believe they set the bed to 50C after a print because that’s the temp that you should remove the print from the bed at. When using PEI if you let the bed cool all the way sometimes it’s really hard to remove the print.
I see. I will set it to cool after the print then warm it again if it seems to be tight when I take it off.
Ya, some materials like tglase are really hard to get off at 20C, but come off easily at 50C, and stick really well 200C+…
