I can see the extruder gear turning, so extrusion is being commanded. My first guess is that the nozzle is too close to the bed, causing back-pressure and preventing extrusion.
Watch the leveling/probing process carefully. Do the bed corners get deflected downward during the probing? It is OK to see a slight deflection on the FIRST PROBE of each washer, but you should not see any deflection of the bed corner on the SECOND PROBE of each washer. If there is any deflection on the second touch, the head will end up too close to the PEI when printing starts.
Suggestions…
Make sure the washers and the nozzle are clean. Before printing, wipe the washers with a rag and some 99% isopropyl alcohol. Right after the nozzle self-cleans on the wiper pad, and while it is travelling over to probe the first bed corner, manually swipe the nozzle with a folded paper towel or non-scratch scotchbrite pad. CAREFUL NOT TO BURN YOUR FINGERS!
If you see downward movement of any corner on the “second touch” probe, STOP the printer. Raise the head, manually clean the nozzle while hot with paper towel or non-scratch scotchbrite pad. Re-prime the filament, and try the print again.
Use Cura to send an M851 command to your printer, and check the response. As I recall, the default Z-offset is -1.43, and should be close to that after factory calibration.
Check Cura to be sure there isn’t an additional negative Z-offset. Look under “Machine, Machine Settings”. You should start with the Z-offset there at a 0.00 setting.
If you have further issues (head too close or too far on first layer), you can change the Z-offset by a SMALL value. I recommend doing this in firmware (the M851 command), following the same process Lulzbot uses during factory calibration – the procedure for that is somewhere in the OHAI documents. Alternately, you can change the Z-offset by a SMALL value in Cura (positive is away from bed, negative is towards bed).
If you haven’t already, upgrade to the 1.1.0.10 firmware (should be default in latest Cura version, or can be downloaded from Lulzbot). The newer firmware is better at sensing a “failed probing” sequence, then re-cleaning the head and re-starting the probing sequence.
For your youtube links… Remove the “s” from “https://” – prefix with just “http://”. For some reason, the secure link causes issues with the embedding here.
