Moarstruder with Taz Pro
Can I make my Moarstruder from my Taz 6 work with a Taz Pro?
It’s an open-source system, so you can put anything you want on it, if you know what you’re doing, but to start, you’d need a custom mounting plate and wiring adapter to do it. Then adjusting nozzle positions, calibrating e-steps…
In my opinion, not worth it. You can get basically the same flow with a high-flow nozzle (Bondtech CHT v6 - with up to 1.8mm nozzle!) and upgrading to a 50w heater in whatever toolhead you’re using on your Pro.
