The Rambo board on my Taz 6 went bad. Unfortunately, my son disconnected a few wires before I could note where they should be connected.
I went to the assembly instructions on the Lulzbot site, but the photo of the Rambo board doesn’t
match my 1.3L board (original). I figured out all but the following:
- The 2 connectors from the Rambo to the display. Which cable goes to which port on the display (the website shows 2 completely separate wires. My original board has a semi-joined harness that has 2 identical harness that go to the display. I can’t tell which goes where)
- Where does the case fan plug into? Does it go to the Fan 2 connection?
- Where does the 2nd extruder yellow and green wire connector go? Does it go to the 2 pin connection to the left of the Heat 0 connector?
- Where does the 2nd extruder double orange wire connector go
