TLDR: Shorted Taz6 wiring, tested fuses for continuity (good), tried&failed to connect.
Hello Friends!
Just picked up my first printer, a legacy Taz 6, with tons of extras. Had it printing great, and killed it promptly after. ![]()
On purchasing the printer, it had an E3D Revo XS installed. I added a contact wire to in order to enable bed leveling and configured it well and ran through a spool of prints.
Then, I wanted to try out the company refurbished dual extruder to use up the 3mm filament that came with the printer and try printing text on my models. What a hellish experience. Truly frustrating. Tore apart the entire assembly for parts. Hate to think that thing cost the original buyer half a grand.
[Sidenote: Anyone want to make an open source 3mm>1.75mm filament converter with me? I think it’s crazy I haven’t seen a small-scale 1.75 bored extruder to recycle outdated 3mm spools.]
Before hooking the Revo XS back up, I decided I wanted to rewire the assembly for looks and to remake the temporary contact wire I added.
Failing at my first attempt to wire the connectors properly, I broke out my tiny breadboard to help solve the wiring. Immediately after getting the wiring correct, I absent-mindedly shorted two of the wires with a pair of pliers.
Tested the SMD fuses and their continuity is good. Saw a suggestion on the boards for the 12v version to remove all connectors but the power and the USB and tried that to no avail. I think I done killed it.
Any advice or tips that I may not have tried? I could splurge for a new RAMBo v1.4, but would also consider other options that may require a little more configuration. Not trying to spend more money on a replacement board than I did for the entirety of the used lot.
Keep on tinkerin’, friends,
h3lmh0lt
