I picked up a used mini from eBay. I downloaded the newest Cura and updated the firmware with default settings. The eBay listing showed that the mainboard was bad; from my diagnostics, it looks like only the y-min is bad; I believe it homes on y-max, so I am under the impression that y-min is only a protection and can be bypassed. I use command M121 which disables the endstops. Everything seems to work at that point (able to home, etc). When I go to print, it starts the wipe procedure. Wiping works, but the bed is moved to a position where the nozzle is 2-3cm in back of the leveling washer. It appears that it is attempting to touch the first leveling washer, but is unable to do so because of positioning.
I am entirely new to Lulzbot (wiping, leveling), so looking for advise on what to try next.
